Routing and QoS
Sir KiKo
Sir KiKo Posts: 11 image  Freshman Member
Hello
I have a router VMG3925-B10C, I read the documentation for VMG routers and now I came across a chapter where everything is not completely clear.
Which interface is defined as br0?
In the Add new static route setting, there is the "Use gateway address" option; which GW will be used when this option is disabled?
Which interface is used when selecting "Use interface > Default"?
Is it necessary / recommended to turn on RIP; I use VMG router as a domestic border router for connect to internet.
Is it good to enable QoS and if so, which Upstream Traffic Priority is the recommended one: Ethernet Priority/IP Precedence/Packet Lenght? We use only music (Spotify), video streams and standard internet browsing.
Best regards,
Martin
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    edited December 2020
    Hello @Sir KiKo Martin,
    I hope that you are well and have made progress.
    I think that in an ordinary domestic situation where the VMG3925-B10C is connected directly to the local telephine network then you do not need to add a static route, because the VMG3925-B10C will be the default gateway for all of the devices on your home (local area) network.
    The VMG3925-B10C will then use your Internet Service Provider as its default gateway.
    I think that you probably also do not need to use Quality of Service (QoS) controls in a domestic situation, unless something is taking all of your network capacity.
    I hope that this is helpful.
    Merry Christmas and Happy New Year 2021.
    Tony
  • Tomokane332
    Tomokane332 Posts: 1 image  Freshman Member
    For my upstream traffic priority, I have to choose between packet length, ethernet priority and IP precedence.
    Which is the best for online gaming?
  • tonygibbs16
    edited June 2023
    Depends on your online game.
    If it uses short packets in real-time, then packet length will be good.
    But it depends...
