[NEBULA] Disable auto provision
Triceratops
I want to stop the function when configuring APs before deploying.
Is it possible to disable-autoprovisioning?
hhmmm... Isn't that equivalent to limiting nebula control center as a web monitoring tool only?0
@Triceratops
Nebula is designed for cloud network management, it's unreasonable to disable auto-provisioning.
Just like @Iwannaquitthegym said, if the auto-provisioning is disabled, NCC will be a remote monitor not a control center.
If you want to setup the configuration before deploying, you can register the device and do the configuration without device connecting to NCC.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
