VLAN interrouting
I'm on an XGS1930-28hp.
I've configured some VLAN on it.
i'd like to interconnect a VLAN with another one directly on the switch. How can i do ?
thanks
Bests
Thomas
Best Answers
Hi @Toulouzzzz,
I can ping the PC in another VLAN in my LAB. Please reference the handbook chapter 2.2 for the configuration.
https://download.zyxel.com/XGS1930-28HP/handbook/XGS1930-28HP_2020.1.pdf
Once the configuration is set, please visit Management > Routing Table > IPv4 Routing Table to check if the routing rule has been set.
Then use tracert to check if the PC sends the packets to the correct gateway.
By the way, I was unable to ping once because my laptop was connected to the Wi-Fi network, which caused it to send the packet to the network's default gateway.
Find the solution
Mask problem
Solved
Hi @Toulouzzzz ,
Could you share with us which management mode you are using, Standalone or Nebula?
Click this link to start: https://bit.ly/3R2Wx52
Judy
Hi Zyxel_Judy
A standalone mode.
I've given an IP adresse to all of the Vlan (10.0.2.254 for the Vlan2, 10.0.3.254 for the Vlan 3...) and a 255.255.255.0 Mask
I set the first computer (Vlan2) on 10.0.2.1 and gateway 10.0.2.254 and the other one (Vlan3) on 10.0.3.1 and gateway 10.0.3.254. but the first cant ping the other one
Is their a firewall on the PC's?
Oh ! Good point
I checked on one of the pc but not on both
I check this tonight.
Hi @Toulouzzzz,
Are you able to ping after disabling the firewall on both PCs?
If the problem still exists, please let me know.
Hi
Still not working.
I've connectés à Switch on port 5 (Vlan3) with those settings :
I ve connected my PC on port 1 (VLAN2) with these settings. Firewall is off.
And here are the IP settings of my switch :
Hi
Everything is created as u explain.
The first time I used tracert, the first ping i've sent was sent to the Wifi as u.
I ve shut down the Wifi on my laptop.
When I ping my switch (pluggin it directly on the same Vlan) tracert is running well.
I tried to ping gateway Vlan3 (10.3.0.254) from laptop connected toi Vlan2 (10.2.0.11) and it works.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
