IKEv2
To set up a VPN which supports IKEv2 I have used the following instructions:
http://onesecurity.zyxel.com/img/uploads/Next-Gen_IKEv2_VPN_Server_Role_CR.pdf
http://www.zyxel-tech.de/files/New-Gen_USG_IKEv2_iPhone.pdf
https://www.google.de/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=2ahUKEwiL2J24hprfAhXloYsKHT5hAH8QFjADegQIABAC&url=https%3A%2F%2Fus.v-cdn.net%2F6029482%2Fuploads%2Feditor%2Fzx%2F8vcjgzsm4487.pdf&usg=AOvVaw2BsE372QdIYpioYkLUW-XV
The setup works on my Windows 10 device (manual configuration) and on my iPhone (iOS 12.1.1) using the handy provisioning feature.
Now the question is how to provision the profile on my iPad? Safari is not displaying the webpage of the ZyXEL in a mobile version (/access.cgi?mobile=1), therefore the profile is not visible to install. Manually configuring the VPN tunnel does not work (no proposal chosen).
What I am doing wrong? Many thanks for any hints in advance.
Regards
Best Answers
Hi @alehzn,
In the current version, iOS provisioning supports iPhone only.
We will evaluate the enhancement for iPad and move the request to the ideas section.
5 -
Hi @alehzn,
Go to Object > Certificate > My Certificates and export the certificate for IKEv2.
Use SSL converter to convert the certificate to .crt file.
Send the .crt file to email on your iPhone/iPad.
Click the .crt file and follow steps on iPhone/iPad to install the certificate.
On iPhone/iPad, go to Settings > VPN > Add VPN Configuration with Type "IKEv2".
Enter the Server of the ZyWALL and Remote ID. The Remote ID is the content in VPN Gateway for IKEv2.
7
Hi @alehzn,
5 -
Hello @Zyxel_Emily
Thank you for your reply.
Do you have also an answer on how to manually configure the IKEv2 tunnel on iPhone/iPad? Apperently it is not possible to set it up manually. All provided information seems to be not sufficient.
Thanks in advance.
Hi @alehzn,
7 -
Hi, I would love to get this working ! However, I'm in the US and can't download the referenced PDF,
Could anyone please share all of the specified settings for phase 1 & phase 2 ?
Thank-you in advance, be it @Zyxel_Emily or anyone else.
Hi @CoreSG,Currently iOS supports the following proposals:In phase 1:AES256+SHA256, Key Group=DH14In phase 2:AES256+SHA256, PFS=none
How iOS device get the IKEv2 VPN configuration from device0 -
Thanks very much !
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
