Our own SSL certificate on captive portal
mslagmolen
I would like to see the option to upload a trusted SSL cert for the cloud based captive portal.
Right now our customers need to accept the certificate before they are redirected to the captive portal.
And allot of my customers find that annoying, so if i was able to upload my own SSL certificate this would realy help.
I guess you meant this?
It's already there, in organization setting menu"You will never walk along"1 -
Right now our customers need to accept the certificate before they are redirected to the captive portal.I thought that was a client behavior for you to check the authenticity of the certificate before authentication. I recall it only appears on the first connection.
- 603 USG FLEX H Series
- 481 News and Release
