OWA and VPN SSL
Dear @Matthieu
Just change the HTTPS port of the ATP like in the screenshot.
you can then use SSLVPN with the public ip adress with the new port behind it like 192.168.1.1:4433
you can still use port 443 for you owa server and ssl vpn at the same time
ok thanks
I will test this
- 441 Beta Program
- 294 Service & License
- 461 News and Release
