[NEBULA] When will NAP disassociate clients?
Triceratops
I'm wondering that what's the criteria of Nebula AP to disassociate the clients? Is there a RSSI threshold? If yes, can we manage it?
Hi Triceratops,
The mechanism of signal threshold to do the roaming is now default disabled on NAP.
So there's no exact signal strength threshold value to disassociate stations.
NAP won't disconnect client even when the signal is poor.
If the customer see the disconnecting behavior, it'll be the stations' action to leave/roam the NAP.
However, here's a good news that the RSSI threshold will be addressed in our further plan.
As the feature applied, you can control the roaming threshold by changing the value of RSSI criteria.1 -
Hi Charming,
Thanks for your reply and look forward to the enhancement.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
