[NEBULA] Where can I set classifier and policy on NSW?
Hi WaYne
It seems to me that ACL on NCC is called IP Filter now (NCC > SWITCH > Configure > IP filtering)
You can customize policy allow/deny, protocol TCP/UDP and Src/Dst IP as ACL function.
However, I am not sure how configure the higher weight in the IP filtering1 -
Hi,WaYne
I know there is the function of QoS in NCC.
You want to know it,right?
Thanks for the quick response,
@GoodDay
Got it, but that is limited to only deny/allow rules. A bit too simple from my point of view.
@SYK
Thanks, thats what I'm looking for, but then again it is not that much of a feature compared to the classifier and policy on GS switches. I'll try it out first.
Thanks you two.
Wayne0
- 588 USG FLEX H Series
- 476 News and Release
