[NEBULA] Network Servers - add more DNS names with same IP
Ludek
Ludek Posts: 5
edited April 2021 in Nebula
We have in our network own mail server and WEB server. It is same server with one IP address. I want to add tho DNS names web.xxx.yy and mail.xxx.yy pointing tto o same IP address. It is not possible. When I try, only one DNS name is possible, when adding second entry, than the field is red and I cannot save.
  • Zyxel_Barney
    Zyxel_Barney Posts: 79
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    Hello @Ludek
    Instead of creating multiple FQDN, I would recommend using wildcards (*) to denote your domain name.
    Example:
    Cheers,
    Barney
  • Ludek
    Ludek Posts: 5
    I know I can use *, but the problem is that www.xxx.yy is pointing to another address to web hosting ...
    I need 3 addresses - www.xxx.yy (IP outside), zakazky.xxx.yy, mail.xxx.yy (internal server)
  • Zyxel_Barney
    Hi @Ludek
    You are right. Wildcards won't help in your current setup.
    I will inform our team whether it is possible to improve the DNS Address Record settings.
    Regards,
    Barney
  • Ludek
    Ludek Posts: 5
    Thank you very much :-)
    Ludek.
  • Ludek
    Ludek Posts: 5
    That's great. Many thanks  :)
Nebula Tips & Tricks
