[NEBULA] AP name changes when moved between Sites
HealthByRo
Why does the custom name of the AP change back to the MAC address when moved between Sites?
We setup new APs (firmware updates, etc.) in a "Staging" site so it doesn't interfere with the production WiFi environment in the room (aka, no SSIDs enabled) and then move it to the actual Site that it is deployed in (so it will have the desired SSIDs of the deployment site).
However, ever AP that we've moved, the name of the AP gets reset to the MAC address. Why?
Seems like the AP name and some other parameters you set for specific device will only apply to the site where you configure it.
"You will never walk along"0 -
Hi @HealthByRo ,
Because the AP's name is recorded per site but not in AP, when the AP is moved to the other site, the AP will show the MAC in the other site.
For example, if an AP is changed the name as AP01 in site A and then moved to site B, the AP shows its MAC as the name if it never changed the name in site B before. Once the AP is moved back to site A again, the AP's name shows AP01 but not its MAC.
Thanks.0 -
IMHO that is a bug, not a feature. When we are pre-configuring a dozen APs for a remote office, we cannot set them up ahead of time and then move them into the proper Site once a contractor installs them physically.0
Do you mean that you move the APs for physical sites but not sites on NCC?
And, the APs are in the same site and the names are changed back to their MAC?0 -
Jon_Snow said:Do you mean that you move the APs for physical sites but not sites on NCC?
No. We configure and test them at one office. Then move them, physically, to the location that it is going to be used AND we moved them in NCC. Problem is ... once we move them in NCC, all of the AP names gets changed back to MAC addresses (not matching the names that we physically labelled on the APs for physical installation)0 -
Just curious, why don't you install the devices in the final NCC site from the very beginning and still do the test at the office?HealthByRo said:Jon_Snow said:Do you mean that you move the APs for physical sites but not sites on NCC?
Again, seems like all the device settings you configure on NCC (name, description, address, etc) are per-site based and it's not saved in the device itself."You will never walk along"0 -
We could do that but it gives a false alert to the team responsible for that site (which could be an outside consulting group) that something is down.RUnglaube said:
I really think that Zyxel should give us an option to move a device from one Site to another with the option of keeping the device names/settings instead of resetting them to defaults only.0 -
Hi @HealthByRo,
Thanks for your suggestion, I'll help to add it as an idea for assessing the feasibility.
@HealthByRo I agree that maintaining device description should be optional.
We should also consider organizations where sharing any information between sites are prohibited.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
