[NEBULA] Can I establish 2 or more simultaneous connection over IPSEC/L2TP ?
Lukasz
Lukasz Posts: 10 image  Freshman Member
edited April 2021 in Nebula
I have 2 users authenticated to connect over IPSEC/L2TP. Both can login VPN if there is no established connection already. If one of them is online, another one can't login, it get stuck on the Phase 2.
  • TomorrowOcean
    TomorrowOcean Posts: 60 image  Ally Member
    First Comment First Answer Friend Collector Seventh Anniversary
    In my understanding is yes, you should be able to login VPN with multiple account.
    Did you see anything related to VPN in the event logs?
  • Lukasz
    Yes, I see something like enclosed.
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    edited February 2019
    @Lukasz
    I notice you also report it on eITS, have reply back please feel free to follow up on ticket.
    Thanks~ :)
    For everyone who might have the issue when connect L2TP tunnel, you can check.
    1. VPN log category, find the negotiation flow stop from which step.
    2. If NSG located behind the NAT server then make sure the port forwarding is correct on UDP        4500 and 500
    3. Check the L2TP setting such as "L2TP pool" (have enough IP for all clients) or pre-share key via      Gateway>L2TP over IPSec client.
Nebula Tips & Tricks
