[NEBULA] Whatsapp - slow response time
we are implementing a wireless solution at a school. It turns out that response time for whatsapp-users is pretty high when on wifi, changing to the 4G -network delivers almost immediately. (Takes about a minute to receive/send a message).
Any idea?
Tnx,
Paul
Any idea?
Tnx,
Paul
Hi all,
don't know what happened but I did a complete rebuild from scratch and the problem is gone...0
Only wahtsapp is affected or is there other service encounter the same problem?
What's your topology looks like.0 -
As far as we can see i'ts only Whatsapp...iMessage and FB Messenger
are working perfect0 -
Done some more testing and is seems that it has something to do with the categories for content filtering on the NSG-200.
I tested and checked the categories for WhatsApp and they were not blocked, so I turned off all of the contentcategories...Result: all of a sudden everything worked perfect!
I have a feeling that there's something going wrong with the filtering...
Hi Chris,
I made a screenshot of the CF-categories we are currently using (these are the ones causing the delay somewhere)
I have enable those category however didn't encounter the same symptom, may I know beside the CF which NSS service has you enable? IDP and APP patrol monitor
BTW, could you also let me know your ISP bandwidth and how many users in this scenario?
/Chris0 -
Hi all,
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
