[NEBULA] Whatsapp - slow response time
paulb
paulb Posts: 16
First Comment Nebula Gratitude First Anniversary
edited April 2021 in Nebula
we are implementing a wireless solution at a school. It turns out that response time for whatsapp-users is pretty high when on wifi, changing to the 4G -network delivers almost immediately. (Takes about a minute to receive/send a message).
Any idea?
Tnx,
Paul
  • paulb
    paulb Posts: 16
    Hi all,
    don't know what happened but I did a complete rebuild from scratch and the problem is gone...
  • ivers
    ivers Posts: 45
    First Comment First Answer Friend Collector Fifth Anniversary
    Only wahtsapp is affected or is there other service encounter the same problem?
    What's your topology looks like.
  • paulb
    paulb Posts: 16
    As far as we can see i'ts only Whatsapp...iMessage and FB Messenger
    are working perfect
  • paulb
    paulb Posts: 16
    Done some more testing and is seems that it has something to do with the categories for content filtering on the NSG-200.
    I tested and checked the categories for WhatsApp and they were not blocked, so I turned off all of the contentcategories...Result: all of a sudden everything worked perfect!
    I have a feeling that there's something going wrong with the filtering...
  • Zyxel_Chris
    Zyxel_Chris Posts: 608
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers 500 Comments
    Hello @paulb
    May I know which CF categories have you enabled before?
    /Chris
    Chris
  • paulb
    paulb Posts: 16
    Hi Chris,
    I made a screenshot of the CF-categories we are currently using (these are the ones causing the delay somewhere)
  • Zyxel_Chris
    I have enable those category however didn't encounter the same symptom, may I know beside the CF which NSS service has you enable? IDP and APP patrol monitor
    BTW, could you also let me know your ISP bandwidth and how many users in this scenario?
    /Chris
    Chris
Nebula Tips & Tricks
