The ability to clear "uplink currently operates at a lower speed 100mbps"
It will probably be a better idea to change that switch
just kidding. Agree with you about the alert flexibility, but really, a switch that has that limitation won't let you get the best performance of your wireless local network.Just a suggestion
, as it happened to me that many times I experienced a downgrade in the wireless speed and after some while I found out it was the switch port switching to 100mbps."You will never walk along"0 -
Don't really see the need for a better switch when the internet connection is only 20Mbps.0
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
