[NEBULA] NSW100-10P not showing online on the Portal
Draegan
Draegan Posts: 3
Zyxel Certified Network Administrator - Nebula First Comment
edited April 2021 in Nebula
Hi all,
I am having issues with this switch, it refuses to come online on the Portal. The firmware on the device is
V1.00(ABGO.0)b2 . Is there any later firmware available?
Thanks in advance.
  • Megatro
    Megatro Posts: 1
    I have the same problem!!
    System Name - NSW100
    Product Model - NSW100-10P
    ZyNOS F/W Version - V1.00(ABGO.1) | 01/20/2017
  • Draegan
    Draegan Posts: 3
    A firmware upgrade via the GUI solved the issue for me. If you still struggle send me a PM and I will share the firmware file if this will help you.
  • Zyxel_Jason
    Zyxel_Jason Posts: 387
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Sales Associate 25 Answers First Comment
    Hi @Megatro,
    I will also PM you later for the latest firmware and the upgrade steps.
    Please check your Forum Inbox.
    Thanks.
    Click this link to start: https://bit.ly/3R2Wx52
    Jason
  • Papa_DIOP
    Papa_DIOP Posts: 6
    edited March 2019
    I also have the same problem. The switch shows off-line !!!
  • Zyxel_Jason
    Hi @Papa_DIOP
    I will PM you for detail information later.
    Please check your forum inbox.
    PS. Since the MAC address and the S/N is the personal information, I will remove it from your post due to security concern.
    Thanks.
    Jason
Nebula Tips & Tricks
