Diffie Hellman Group support to 15
Zyxel_Stanley
This discussion was created from comments split from: Diffie Hellman Group 15
Description: Currently IPSec VPN Diffie Hellman Group only support for group 1, 2, 5, 14. But not group 15.
Click like if you think the feature is useful and beneficial.
This artical states that even DH15 is far to low for security.At least go to DH19
In my view the CISCO doc is absolutely right, DH14 is the absolut minimum at the moment, 19-21 would be recommended. German BSI gives the same advice.
The more configurations to be done, much better for the admin.
I will always try to configure the most security for me and my customers and partners.0 -
at least DH19 in near future?
In ZLD 4.60, the DH Group 19, 20, 21 is support.
For 128-bit security level, DH Group 19 is recommend. (instead of DH Group 15)
For 192-bit security level, DH Group 20 is recommend. (instead of DH Group 18)
For 256-bit security level, DH Group 21 is recommend.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
