[NEBULA] Setup NWA1123-ACv2 to repeater mode
Thank you very much for your detail instruction.Nebula_Barney said:Hi @Ngoc_Le_VN01
The method involves a default mesh-ID present among all Nebula APs.
Three conditions must be fulfilled for a newly added AP without wired connection to automatically join the Smart Mesh:
1. At least one Nebula AP acting as a root
- Smart Mesh enabled
- Wired uplink port is connected
2. Newly added AP is using latest firmware
3. Newly added AP is added to the same Nebula organization as root AP
When you power-on your new AP without a wired uplink connection, your AP will turn into repeater mode and scan the vicinity for the default mesh-ID. Your root AP will then check if this AP is registered under the same Nebula organization. Once verified, your root AP will allow your new AP to form a mesh and is allowed access in to the local network.
At this point, new AP connects with NCC, receives site-related configurations, and finally connects to the true mesh-ID.
Regards,
Barney Gregorio
Ngoc0
- 588 USG FLEX H Series
- 477 News and Release
