Zyxel VES1724-56B2
Hi Avivm,
Have you check the user guide?
Supposedly user guide will included the pin assignment mapping table.
Cheers,0 -
I haven't received user guide, where can I find it online?0
Hi Avivm,
You can check with ZYXEL local support in your region to get the user guide.
As I remember it should be standard V type telco 50 cable. telco-50 female pin assignments will like below:
Thanks! will do0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
