DHCP Static Host Setting Conflict, error 4024
When trying to reserve a static ip on a vlan interface on a ZyWall 310 running V4.33(AAAB.0) firmware I receive the error:
CLI Number: 30
Error Number: -4024
Error Message: 'DHCP static host setting conflict.'
Error Number: -4024
Configuring from the web or CLI makes no difference. Using a different IP with the same MAC address produces no error, but I need to use this one particular IP.
- The problematic IP doesn't appear in the DHCP table.
- I've scoured every device in my environment looking for any other use of it and found nothing.
- I've used every net mapping tool I can think of and found it nowhere.
- Of course I've restarted the entire network.
Any advice would be much appreciated.
Thanks,
Bryan
Hi @Bryan
This log is happening when you configured the same IP address in DHCP server.
So system doesn’t allow to save it.
Please check if you configured the same static IP in the other interface.
(Go to Configuration > Network > IP/MAC binding and check all of DHCP setting one by one)
Thanks for the quick reply.
The mystery address is 10.0.10.2 on vlan10. As you can see (attachment "ip mac binding"), I can configure 10.0.10.3.
No addresses in 10.0.10.0/24 are configured anywhere other than the vlan10 interface config (attached "vlan 10"). The only one which appears in ip/mac binding is 10.0.10.3 for vlan10, just as you'd expect.
Thanks again,
Bryan0 -
Unplug the cable of the interface vlan10 and configure on another interface for VLAN10 to add 10.0.10.2
I appreciate your taking the time to make the suggestion, PeterUK, but there are other easier solutions to the problem. I'm seeking to understand it. (I'm the sort of guy who goes to the doctor with a rash and says, "Yes, I know it will go away in a few days but I want to know what it is."
Hi @Bryan
Was the IP address configured in the other interfaces?(except VLAN10)
Can you also check 10.0.10.2 in other interfaces?
I appear to have solved the problem by waiting until 4:00 am, backing up the ZyWall's configuration, initializing it to factory defaults, and restoring it while the world (my part of it, anyway) slept. Apparently the problem was some log-free gremlin below the level of anything the interface can see.
Thanks for the help just the same.0 -
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
