Slow Internet Connection via GS1900-24e
fritzi07
fritzi07 Posts: 4 image  Freshman Member
edited August 2022 in Switch
Hello
I use the Swith GS1900 24e and have a speed issue. Connecting directly to the router (ASUS RT AC88U) I get the full speed (600 Mbit/s down) and connecting via the Switch, the speed drops to about 100 Mbit/s. I use the Switch with the factory seetings and all cables used are Cat6.
  • Sakura_T
    Sakura_T Posts: 101 image  Ally Member
    edited June 2019
    It seems like the port speed is incorrectly in 100M .
    Have you checked the port status in web interface?
    Try force it in 1000Mbps, or have some cable swap test.
  • fritzi07
    edited June 2019
    Thanks. The speed for the ports is on Auto/duplex and the monitor shows 1‘000M.
    Before posting in the forum, I tried the following:
    1. Reset to factory settings
    2. Only connect the router and one PC to the switch
    3. Test the cables by connecting each directly to the PC.
    Unfortunately, this did not help, i.e direct connection yields 600 MBit and via Switch between 60 MBit and 120 MBit. I have to admit that I am inexperienced with managed switches.
    Any other idea? Is there a setting, I have to change?
  • D_Shadow
    D_Shadow Posts: 18 image  Freshman Member
    First Answer First Comment Friend Collector Fourth Anniversary
    You've mentioned that all cables are CAT6, I'm not quite sure but you can try to make a test by using CAT5e cable. Maybe there is some incompatibility between CAT6 and GS1900.
    Peace
  • fritzi07
    After a few factory resets and re-connecting of the cables, all of a sudden it’s working fine.
    Despite not knowing where the issue was coming from, thanks all the same.
