Energy Efficiency of GS19.. Series
kprueckl_dt
kprueckl_dt Posts: 4 image  Freshman Member
edited August 2022 in Switch
I'm currently running a bunch of enterprise switches in a home environment for training purposes. Therefore I'm interested in low energy consumption and noise levels (so also low heat dissipation), but still essential enterprise functionality (VLAN, QoS - especially with VoIP, data flow).
I already have a GS1910-24 running, which is passively cooled and uses sFlow (which is nice feature, but I've not found any good tools to visualize).
This one together with a Cisco switch should be replaced and I'm attracted by the Nebula cloud monitoring feature, which I expect would be a good successor for sFlow visualization (not that detailed, but better overview).
Since GS1910 is EOL, I have to decide between GS1900 and GS1920 (still staying on 1000BASE-T - 10GBps is still wasting energy).
Cisco is providing in their data sheets energy usage based on 0%, 10% and 100% traffic and a weighted average. This is especially interesting for PoE switches, since the total max. power consumption is not reflecting the real scenario with just a few 4W devices connected and so no efficiency metric.
So, I'm curious if you have more detailed power metrics especially for
  • GS1900-10HP
  • GS1900-24
  • GS1920-8HPv2 (heat dissipation is insanely high compared to GS1900-10HP)
  • GS1920-24v2
GS1900 would be a trade-off since no Nebula cloud, but more efficient.
Influence of SFP modules would be good to know as well (since spec says 3.3V with 300mA, I guess 1W is calculated per SFP into the max consumption usually?)
By the way, why has GS1910 series been discontinued?
Thx,
Klaus
  • kprueckl_dt
    edited June 2019
    Sorry, can this be moved? - I've accidentally posted to "Ideas".
    Alternatively, please treat as datasheet improvement idea...
  • kprueckl_dt
    Thx!
  • kprueckl_dt
    One more question: Are the numbers from your list including SFPs? I would guess it is with all ports connected with 1Gbps devices, right?
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    Hello @kprueckl_dt
    Our full load test is where all copper & fiber ports inserted, SFPs are included.
    Zyxel_Lucious
