GS1900-8HP Login
I am able to login to the GS1900-8HP using Windows 10 and setting a static address 192.168.1.10. I changed these settings: admin password, SNMP Global State to disable, SNMP Group string from "public" to "nonpublic." This eliminated the warning at the start of the GUI for Admin Password and SNMP Public settings.
PROBLEM: I cannot access the switch from Linux when the switch is in a reset state, or after power loss. After reset / power loss the switch defaults to a static addressing and I can access the switch from Windows 10 using 192.168.1.10, but I cannot access it using Linux. Either, I am not setting up Linux Static Addressing correctly or the Linux GUI for Static Addressing is buggy. I have not used Linux command line networking.
When I set the switch to dynamic addressing I am able to access the switch login and login appropriately with Linux.
I DO NOT want to rely on Windows 10 to access this switch after power off.
Hi @bilbo
We had our local test with Linux platform binding static IP and GS1900-8HP, and it works just fine.
When you try accessing switch via web-GUI on Linux, could you ping the switch?
You may also check following info,
1 . ARP table on Linux, is the switch entry on it?
2 . MAC table on switch, is the Linux entry on it?
Zyxel_Lucious
5
What is the static IP of your host when using Linux?
It's seemingly you didn't set an IP within the same subnet 192.168.1.X, hence no communication.
I updated the Firmware to V2.40(AAHI.1) 03/30/2018
I don't think I've ever gotten to a static IP on the Linux Host, that is my problem. I need some help from someone who knows the Linux GUI. Using Ubuntu 18.04: Settings>Network>Wired>IPv4 TAB>IPv4 Method has four radio buttons: Automatic, Manual, Link-Local Only, Disable. Choosing Manual gives
Addresses
Address 192.168.1.1 Netmask 255.255.255.0 Gateway 0.0.0.0
DNS Automatic ON or OFF ?
Routes Automatic On or OFF?
Checkbox: Use this connection only for resources on it's network Checked or Unchecked?
I'm following the same approach as shown through a Windows 10 box. The Host IP address is NOT the same as the Network card IP address?
I guess I'm completely lost. IF I want to change the Host to 192.168.1.x I CANNOT do that by changing the address of the Network Card?
I probably need some basic Networking How-to for Ubuntu. Any suggestions?
Sakura_T I'll start by looking at command line ifconfig and working from there. I've been wasting my time, and yours, with this GUI approach.
It seems to me that all you need to set is simply "manual" and IP address.
Peace.
D_Shadow my Network GUI window looks different, but all the basics are the same. That has NOT worked. After I resolve this issue I'll get back to you with a screen shot and a solution.
I'm using Ubuntu 18.04. Thanks for your time.
It's obvious I'm going to need some help on this issue. This is not some Mission Critical issue, so I'm going to save my sanity, by NOT letting it get me worked up. If I have to, I'll replace the switch with a basic 4 port switch and be done with it. Thankfully I have AC in my office/studio.
My new question is: is there anybody here who has accessed this GS1900-8HP switch from Linux after it has been reset? I'm sure there is.
I include some edited screenshots from yesterday.
I'm capable, but not "the expert" on networking. Any suggestions, I thank you, in advance.
I'm going to set up a Linux box, off to the side, so I can tinker with this problem / project.
Hi @bilbo
Zyxel_Lucious
5 -
Hi Lucious
MAC table could be the problem. I'll look into that. I have never set up the switch beyond changing the password. I'm able to add devices and computers to the switch. Such as a streaming BluRay player that works fine.
- 396 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 86 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
