v1.38 Dashboard Issues
MCFH
MCFH Posts: 25 image  Freshman Member
First Comment Friend Collector Eighth Anniversary
So I load my dashboard and get this error (I have cleared Edge's cache too)
This is being caused by the client usage widget
Error
Failed to load interface list
Error Code: (500)
/api/show/gui/widget/client/usage
«134
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,457 image  Zyxel Employee
    Hi @MCFH ,
    To better assist you, please provide the Nebula organization & site name and enable Zyxel support for our checking.
    Zyxel_Judy
  • MCFH
    Hi
    I have shared privately
  • SSC
    SSC Posts: 2 image  Freshman Member
    I have the same problem. So if a solution exists. I will appreciate having it.
    BR
  • GiuseppeR
    GiuseppeR Posts: 730 image  Guru Member
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
    Hi @MCFH and @SSC
    do you get this error with local access or remote access triggered from Nebula?
  • MCFH
    Local access
  • YanShadowGT
    YanShadowGT Posts: 23 image  Freshman Member
    Hi, I have the same problem
  • Albe
    Albe Posts: 2 image  Freshman Member
    Zyxel Certified Network Engineer Level 1 - Nebula First Comment Fourth Anniversary
    Alberto
  • Zyxel_Judy
    Hi Users,
    We are currently looking into this and will keep you updated as soon as we have any findings.
    Zyxel_Judy
  • Asgatlat
    Asgatlat Posts: 133 image  Ally Member
    any news ?
    not want to apply 1.38 FW in production with this bug 😕
  • JakobH
    JakobH Posts: 4 image  Freshman Member
    I get the same error on USG FLEX 50HP, running 1.38. Tested 3 browsers, Firefox, Edge & Chrome, all with the same result.
    Anyone running 1.38, whitout this error?
