Link-sticking, double wan configuration, firmware 4.30
2»
  • Grant
    Grant Posts: 48 image  Freshman Member
    First Answer First Comment Friend Collector Eighth Anniversary
    Always on.
  • Blabababa
    Blabababa Posts: 151 image  Master Member
    you don't need to enable it manually, just enabled in default
  • Grant
    In firmware 4.33, the link-sticking does not work or does not work correctly!
    No traffic through one interface
  • Zyxel_Stanley
    Hi @Grant
    The link sticking function is to stick the session on one of WAN interface when destination address is the same until the session expires.
  • Grant
    V4.31(AAAC.1)ITS-WK52-r86652 is working correctly! I have a uniform load on the adaptersю
  • Zyxel_Stanley
    Hi @Grant
    Link sticking will keep traffic working on same WAN interface when destination is the same one.
    It can prevent some of secure WebSite(Bank) those will check source IP address per session. If IP address changed, then will deny the session.
    So link sticking function is required.
    According to your scenario ge1 loading is higher than ge2. The reason should come from many sessions connecting to same server.
    Before sessions expired from USG these sessions will always pass through by ge1.
  • Grant
    edited June 2019
    Wrr algoritm dont work!
  • Grant
    The second wan is not used!
    On firmware 4.31 everything worked fine. Rx / TX on both adapters was about the same!
  • Grant
    My old gateway works better than new!
  • Zyxel_Stanley
    Hi @Grant
    The firmware for better balancing algorithm is ready. I will send you firmware by private message.
