[Release Note] Nebula Control Center - 20.10 software Release!
Zyxel_CSO
Zyxel Nebula Control Center Release Note
Common NCC (Organization,Site-wide,etc.):
- Introduced Nebula Identity Federation Service (NID FS), enabling federated login through multiple identity providers, including Microsoft Entra ID and Google Workspace, using industry-standard OIDC for device-initiated authentication flows. (Nebula Pro Pack license is required)
- Added Passkey support to Nebula Cloud Authentication Server (NCAS), enabling passwordless sign-in for supported authentication scenarios. (Nebula Pro Pack license is required)
- Added VLAN-based Topology views to better visualize network segmentation. (Nebula Pro Pack license is required)
- Enabled select Topology features for Base Pack organizations.
- Enhanced MSP admin operations with centralized access to device event logs. (Nebula MSP Pack license is required)
- Introduced a one-click Replace Device feature for seamless hardware replacement. (Nebula MSP Pack or Pro Pack license is required)
- Gain instant insight into service health with our new Status Page.
- Enabled PAYG management for Delegated Admins.
- Refined the License Assignment UI/UX.
- Refined the license change log UI/UX for USG FLEX H series. (Nebula Pro Pack license is required)
- Refined the Trial license banner UI/UX for improved clarity.
- Refined the Device Event Log UI/UX
Wireless LAN (WLAN):
Important: To provide a more secure and reliable wireless service, Nebula have enhanced the Captive Portal Theme Profile security design. Updating the Captive Portal Theme Profile may invalidate existing user sessions. As a result, connected users, including those using mobile devices, may be required to log in again after the update is completed.- DPPSK is now supported on WPA3 SSIDs, combining personalized security keys with the latest encryption standards. (Nebula Pro Pack license is required)
- Users can now sign in Captive Portal seamlessly with Nebula Identity Federation Service (NID FS) or use modern passwordless Passkeys for NCAS logins. (Nebula Pro Pack license is required)
- The brand-new Roaming Dashboard provides real-time visibility into client transitions between supported APs, helping you optimize wireless coverage. (Nebula Pro Pack license is required)
- Real-time AFC and ACS reports are now available in Live Tools, helping you optimize spectrum usage and minimize interference. (FWA7 Root plus and leaf plus support only)
- PTMP Device-Level Bandwidth Control lets you set precise bandwidth limits on WISP devices to help prevent congestion and maintain a stable shared network.
Switching:
- Add power input source (Adapter/PoE-In) to Hardware Monitor.
- Add support for “Auto, SFP28, QSFP28, DAC25G, and DAC100G” options in Media Type.
Security Firewall:
- For USG FLEX H series, users can now sign in Captive Portal seamlessly with Nebula Identity Federation Service (NID FS) or use modern passwordless Passkeys for NCAS logins (Nebula Pro Pack license is required)
- For USG FLEX H series, remote access VPN users can now sign in via NID FS. (Nebula Pro Pack license is required)
- Expanded USG FLEX H Series VPN PSK supported characters for Manual-Link, improving compatibility with on-premises models.
- Added API-driven DDNS integration with Cloudflare DNS for USG FLEX H series.
- Added DHCP lease table to Live tools.
Security Router:
- N/A
Broadband Router:
- N/A
Accessory:
- N/A
Zyxel Nebula Support
"DPPSK is now supported on WPA3 SSIDs, combining personalized security keys with the latest encryption standards. "
Could this be clarified since (as far as I know) WPA3 does not support DPPSK
Hi @dukisha016
The WPA3 DPPSK needs to use different authentication process with WPA2 DPPSK. In the new firmware, we implement the standard flow to support WPA3 DPPSK.
Zyxel Melen0
- 234 Nebula Ideas
- 6.7K Security
- 707 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
