50H 1.39 firmware DDNS error?
kelmi
kelmi Posts: 66
First Comment Friend Collector Eighth Anniversary
image  Ally Member
After upgrading from 1.38 to 1.39, DDNS stopped working. Dyny Basic. It keeps informing "user field is empty". It is not empty, profile was working perfectly with 1.38. Deleting and reimplementing the profile does not help.
K
«1
    PeterUK Posts: 4,818
    image  Guru Member
    edited August 11
    What bit says "user field is empty"? screenshot
  • kelmi
    kelmi Posts: 66
    image  Ally Member
    image  Guru Member
    edited August 11
    Hmm I think I know the issue it seems Dyny Basic is missing Username box for DDNS Account ? Could you check in 1.38 if it was ever there?
    but to workaround it use DDNS Type user custom
    with the Username as Email and password add your Domain and in the following
    URL Hostname: apiserver.dynu.com
    URL Path: /nic/update?hostname=
    and that will work
  • kelmi
    kelmi Posts: 66
    image  Ally Member
    edited August 12
    Dynu seems to be the only DDNS account, where the Username- field is missing in 1.39. I don't recall, if Username-field was in 1.38, according to User Manual, seems to be so.
    I'm not sure I understand what you mean with your idea? I'm not too familiar with this topic.
    K
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,220
    image  Zyxel Employee
    Hi @kelmi,
    We are checking on this issue since we can replicate it. I will update you once I get further information.
    Zyxel Melen
    image  Guru Member
    edited August 12
    as said you can do the Dynu Basic by user custom
  • Maverick87
    Maverick87 Posts: 508
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate
    image  Guru Member
    edited August 12
    There is a note on dynu website.
    For the Zyxel USG50, latest firmware has removed "Username" field but that does not affect the IP update process. As long as you enter the correct "Domain name" and "Password", IP address for your domain name will be updated. The password should not have any symbols.
    Probably this affect also the newest H series.
  • kelmi
    kelmi Posts: 66
    image  Ally Member
    Thank's for the info. Seems to be not the case. It really affects the IP update process within or with USG50H.
    K
  • Zyxel_Melen
    Hi @PeterUK @Maverick87 @kelmi
    Thanks for your discussion. Let me to update the behavior for Dynu Basic DDNS service option.
    This option doesn't need to enter username. You only need to enter the options in setup page(domain/password). This issue is because of the new feature.
    The issue has been addressed and will be fixed in the next firmware release.
    Zyxel Melen
  • Maverick87
    image  Guru Member
    Hello @PeterUK, @kelmi,
    today I received the weekly firmware for my 500H and seems that this error is fixed.
    Now is possible update a dynu DDNS via the Dynu Basic/Premium type.
