cloud dns filter keeps blocking a site, doenst matter what i do on the PC or Firewall
AMI
AMI Posts: 34
image  Freshman Member
Dieser Server konnte nicht nachweisen, dass es sich bei ihm um ast-systec.com handelt. Das Sicherheitszertifikat stammt von dnsft.cloud.zyxel.com. Dies kann auf eine Fehlkonfiguration zurückzuführen sein oder auf einen Angreifer, der Ihre Verbindung abfängt.
  • AMI
    AMI Posts: 34
    ok, update. apparently the site adds www in front of it after i typed it without it,(that was not really visible in the firewall logs) so add a * before the URL now did the trick. So i guess the firmware did resolve it.
  • AMI
    AMI Posts: 34
    edited September 7
    V1.38(ABZI.0)
    Lastest Firmware
    Disabled Rep, DNS and URL - makes no difference.
    Added to allow list - no difference
    flushed DNS on PC, tried different PC - no difference
    flushed cache on FW/CMD - no difference
    IP exception - no difference
    With all them disabled - the block wont even show up in the Rep Filter Stats
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,220
    image  Zyxel Employee
    Hi @AMI
    Did you flush DNS after change firewall setting? PC might cache the DNS resolution, which is direct to the firewall. Windows please use "ipconfig /flushdns"
    Zyxel Melen
  • AMI
    AMI Posts: 34
    edited September 7
    All and everything, even a new pc that never accessed the site. ALSO i just noticed, on the FW itself, it shows 1.38 as latest firmware, but that is obviously not correct as its 1.39. So i try manual update now (Check now button does not show that there is a newer firmware)
    noting that it actually sits on autoupdate but it did not do it!
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,816
    It looks like the Firmware Type is set to "Stable" under Nebula > Site-Wide > Firmware Management. This means the firmware won't update automatically if the current firmware version is stable version (1.38 currently), and it's also why manually clicking "Upgrade Now" isn't returning any available update.
    We'd recommend changing the Firmware Type to "Latest" and running "Upgrade Now" again, so the firewall can update to the latest firmware version.
    Zyxel_Judy
  • Zyxel_Judy
    It appears that the URL ast-systec.com being flagged as High Risk and listed as a malicious site is expected behavior.
    If you believe this categorization is incorrect, please click this link to submit a request for it to be reviewed.
    Zyxel_Judy
  • Zyxel_Judy
    If you've already added the URL to the Allow List (Security Services > Reputation Filter > DNS Threat Filter) but are still unable to access the site, please download and share the diagnostic file so we can take a closer look.
    Zyxel_Judy
  • AMI
    AMI Posts: 34
    edited September 7
    see update
  • AMI
    AMI Posts: 34
