LTE firmware for SBG3600
  • secu_guest
    secu_guest Posts: 6 image  Freshman Member
    Many thanks. What does it mean latest letters at the firmware name MS and LO? It is compatible with EU frequency LTE bands?
    And what is WWAN driver? I'm used to the name that wwan is GSM module (on laptops etc..)
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,539 image  Guru Member
    Hi @secu_guest
    Regarding the "MS" and "LO", they are part of the naming rule.
    About "WWAN driver", the SBG3600 supports wireless Internet connection not only from the built-in LTE module but also from USB-pluggin 3G dongle.
    The WWAN driver refers to 3G dongle. It ensures the Internet availability.
  • Uli
    Uli Posts: 1 image  Freshman Member
    Hi @Zyxel_Cooldia,
    can you send me the LTE Firmware as well please?
    I am running:
    Router firmware: V1.00(AAKO.9)
    WWAN Package Version: 1.15
    LTE firmware: ALT3100_04_05_06_10_B8_LO
  • Zyxel_Cooldia
    edited July 2019
    Hi @JamesW @Uli
    I will send your firmware via private message.
  • qubic
    qubic Posts: 5 image  Freshman Member
    HI need new firmware upgrade for LTE on SBG3600 currently on ALT3100_04_05_10_B8_LO
  • Bob_C
    Bob_C Posts: 222 image  Master Member
    Hi qubic,
    May I know your router firmware version?
    Is it V1.00(AAKO.9)C0?
    Thank you.
    Regards,
    Bob
  • qubic
    Hi Bob Firmware is V1.00(AAKo.9)
  • dcarb
    dcarb Posts: 1 image  Freshman Member
    I have a issue, the download is very slow by LTE.
    It's a firmware issue?
  • Bob_C
    Hi qubic,
    I will send you a private message with the firmware. Please go to the "Inbox" at the upper right side of the page.
    Regards,
    Bob
