Nwa1123-ACV2
Hi.
Does thie AP support wireless client mode so I can attach a printer to the network interface and use it wireless?
I can't seem to find the operating mode "wireless client" in the settings. Firmware is updated.
The NWA1123-AC v2 doesn't support client mode.
If you really need the AP support client mode, you can find the Zyxel older model like NWA1100-NH, NWA1121-NI, NWA1123-NI or NWA1123-AC.
They all support client mode!
I have used one of them before~
why remove important and basic functionality when upgrading our accesspoint…...
Hi @FrankIversen
NWA1123-AC v2 by default design does not support client mode but it supports WDS with root and repeater modes, it is because very few of our customers request the feature,therefore, we determined to obsolete this feature support and focus more on the enhancement for enterprise wireless mobility features.
In fact we currently support another feature called: WDS with wireless bridge should be able to meet your application to attach a printer to the network interface and use its wireless.
The topology of wireless bridge LAN:
Internet <->LAN<-> (RootAP) <Wi-Fi> (Repeater AP) <->LAN<->Other LAN Device (like printer or so on)
To enable bridging on the AP's GUI, select the option "Enable WDS Wireless Bridging" when you set up a repeater AP.
It's supported on the new AP models: WAC6103D-I ,WAC6500 series and NWA1123-AC PRO APs.
Hello
How one can enable WDS wireless bridging from NCC ?
The WDS in NCC called Smart Mesh. The AP model support as below:
so if we use Smart mesh (what we of course would due when we want to use wireless client mode for the lan port), this will work?
As @IKLe mentioned that WDS(in standalone AP) in NCC called Smart Mesh. But Smart mesh is not suitable for your current scenario, its function is to extend the wireless signal. Smart mesh with wireless bridge mode is the application that meets your requirement.
It will be supported and released around mid-January next year, however it doesn't support on NWA1123-ACv2 AP, it will be supported AP models: WAC6103D-I ,WAC6500 series APs.
Thanks!
Thanks Zyxel_Panda
do you mean sometime by mid-Jan 2020 the WDS will be supported with NCC?
Hi @RTH10
I mean Smart mesh with wireless bridge mode feature will be supported with NCC around mid-January 2020.
Actually, the WDS term we called it for standalone AP. if AP is managed by NXC or USG controllers, the WDS term we called it Zymesh, however, if AP is in cloud mode which is managed by NCC, the WDS term we called it Smart mesh.
Thanks!
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
