GS1900-8 trunking?
I have a ubiquiti ap in my barn that is transporting valns 10 and 90. This connects to my GS1900-8 on port 8. Ports 1 through 4 I want to setup on VLAN 90 for my ip cameras and ports 5 thru 7 on VLAN 10. Can you show me how to configure my GS1900 that has software V2.40(AAHH.1)? I know I am missing something in the trunking portion.
Thanks.
Glenn.
Hi @Stampeder
Enable VLAN Trunking on ports allow frames belonging to unknown VLAN groups to pass through the Switch.
Therefore, if you only have VLAN 10 and VLAN 90, you don't have to enable it because you have already fixed the port as the member of these two VLANs
Enable ingress filtering, switch will discard incoming frames for VLANs that do not include this port in its member set.
Normally, we will not configure this feature on uplink port
Therefore, you don't need to enable it, either
Zyxel_Derrick
6
Hi @Stampeder
Please follow the steps below:
1. go to "Configuration > VLAN" to add VLAN 10 and VLAN 90
2. go to "VLAN Port" and select VLAN ID 90 to configure port 1 to 4 untagged and port 8 tagged
3. go to "VLAN Port" and select VLAN ID 10 to configure port 5 to 7 untagged and port 8 tagged
4. go to "Port" configure PVID 90 for port 1 to 4 and PVID 10 for port 5 to 7
Then you can achieve your setting
Zyxel_Derrick
Just one more part to my question:
Should port 8 be set to VLAN trunk enabled and also what about filtering?
Thanks.
Glenn.
Thanks very much for the explanations and help.
Best regards.
Glenn.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
