Questions about traps in xgs3700-24
Hello Everybody.
I need your help to get me a information to how to solve the following alarm:
zyTransceiverDdmiTemperature OutOfRange This trap is sent when the transceiver temperature is above or below the normal operating range. MAX: 78 MIN: -13
zyTransceiverDdmiTxPowerOutO fRange This trap is sent when the transmitted optical power is above or below the normal operating range. MAX: 2 MIN: -7.9
zyTransceiverDdmiRxPowerOutO fRange This trap is sent when the received optical power is above or below the normal operating range. MAX: 2.50 MIN: -20
zyTransceiverDdmiVoltageOutOf Range This trap is sent when the transceiver supply voltage is above or below the normal operating range MAX: 3.70 MIN: 2.90
zyTransceiverDdmiTxBiasOutOfR ange This trap is sent when the transmitter laser bias current is above or below the normal operating range. MAX: 85 MIN: 15
What do I need to check in order to solve those alarm when its occurs
Hi @VictorZX
Welcome to Zyxel community!
The high alarm threshold/low alarm threshold of ddmi information depend on connected transceiver module.
If you received any trap relates to ddmi, you can try to do some cross test, for example, plug this transceiver into other switch to see if same problem exist.
If yes, we would suggest that it's better to change another transceiver since this transceiver may has some problem.
Best Regards,
Arisa
5
Hi @VictorZX
Best Regards,
Arisa
5 -
OK thank
zySysMgmtUncontrolledSystemReset said that switch automatically restart. why do that happen?
Hi @VictorZX
When switch detects unexpected reset which is not performed through management interface, such as WEB, CLI, SNMP..., it will send trap zySysMgmtUncontrolledSystemReset after system boot finished.
Best Regards,
Arisa
ok I understand but why do that happens? for what reason switch unexpected reset ?
Hi @VictorZX
The message indicated that switch is rebooted due to unknown reason, that's why switch needs to send trap zySysMgmtUncontrolledSystemReset after reboot finished. When the unexpected reboot occur you may need to collect the switch tech-support file and contact Zyxel for profession support.
Best Regards,
Arisa
- 588 USG FLEX H Series
- 477 News and Release
