XGS1910-48 firmware update error - product mismatch
選項
advanced
advanced 文章數: 1 image  Freshman Member
已編輯 February 2021 於 乙太網路交換器
Hello, I downloaded the XGS1910-48 V2.00 firmware and uploaded it to switch using TFTP but get this error -
Firmware>load 192.168.1.2 200AABW0C0.dat
Downloaded "200AABW0C0.dat", 4581335 bytes
E firmware 00:33:50 10/firmware_compatible#570: Error: Product mismatch (Product ID was a9, have 99)
Error: Image error
The release note in the archive showing it is for XGS1910-24, could this be the problem?
If the firmware is mismatch, where can I find the correct one, thanks.
  • Zyxel_Jason
    Zyxel_Jason 文章數: 432
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    image  Zyxel Employee
    選項
    Hi @advanced ,
    Welcome to Zyxel community!
    XGS1910-48 is using the same firmware as XGS1910-24.
    However, please note that if you are trying to upgrade firmware from V1.00 to V2.00, you may need to upgrade the firmware in order like below:
    Hope it helps.
    Jason
  • VincentSanders
    VincentSanders 文章數: 1
    選項
    that is very useful to know but is there any way to obtain the old 1.00(AABW.2) firmware?
    I have a switch with 1.00(AABW.0) I would like to upgrade
  • Zyxel_Jason
    選項
    Hi @VincentSanders ,
    Welcome to Zyxel community.
    Please refer to the link below for the firmware of XGS1910 series.
    XGS1910-24
    XGS1910-48
    For example, XGS1910-48HP V1.00(AABW.2)
    Hope it helps.
    Jason
