AP firmware download failed. Reason: Device storage is not enough..
Wilson_ks
Wilson_ks Posts: 3 image  Freshman Member
edited April 2021 in Security
in my Zyxel USG60w0s log I've just found the follow row:
How to fix it?
Thanks.
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,590 image  Zyxel Employee
    It seems the device disk is full, can you post the command result,
    Router> show disk
  • Wilson_ks
    edited June 2018
    I cannot open the console because the certificate issue.
    But I've maybe found another solution, I've manual uploaded the new firmware on "Firmware Package", now I've:
    V4.15 - Running
    V4.31 - Standby
    How could I run the V4.31? I'll not lose my settings?
    Thanks.
  • Zyxel_Cooldia
    Hi @Wilson_ks,
    Issue had been solved by remote checking, it is okay now.
    You can upgrade to V4.3X directly on partition 1.
  • c7ic
    c7ic Posts: 4 image  Freshman Member
    Hello!
    I have same problem. USG 60w -- AP Firmware download failed. Reason: Device storage is not enough..
    Auto Upgrade disabled.
    How to fix it?
    Thanks.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,481 image  Zyxel Employee
    Hi @c7ic
    Can you upgrade USG firmware to 4.33WK19 first.
    ftp://ftp.zyxel.com/USG60W/firmware/433AAKZ0ITS-WK19-r88384.zip
    And try to enter this command to flush memory.
    Router> debug system _disk-cleanup
    After cleared memory, and try to download AP firmware again.
