VMG Accessing ARP table from CLI
elavaud
in Home Router
Any ideas?
Thanks!
Thanks!
Hi there
I think the CLI will no open for user.0 -
Yes it is I can already do a bunch of commands. However what is not open is the documentation...0
This works really well for us, thank you! Facing same issue here. Help is appreciated.
Hello all,
There is a 2013 document of the Zyxel CLI for a VMG1312 -B10A at https://support.aa.net.uk/images/6/6c/VMG1312-B10A_CLI_Reference_Manual.pdf
It mentions a command called ARP show which might do what you would like.
Whether you have access to it depends on the level of login that you use, and the firmware version you have.
- it does not show on my VMG1312-B10D if I login with admin
Kind regards,
Tony0
- 384 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 79 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 909 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 898 Nebula FAQ
- 415 Security FAQ
- 234 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
