MULTI SSID - How make it !
DamienSIMON
DamienSIMON Posts: 1 image  Freshman Member
edited April 2021 in Security
Hi friends !
First of all, I'm sorry for the quality of my english... (I'm French!)
I recently bought a USG210 + two WAC6103D-I
I would like to set up this configuration:
LAN1: 10.144.209.1/24 (private network or are connected pc, servers, printers):
DHCP enabled
LAN2: 172.0.9.1/24 (network where access points are connected)
DHCP enabled
I would like :
SSID1: Privatewifi (distributing the IP range 10.144.209.0/24)
SSID2: Hotspot_Clients (distributing the IP range 10.10.10.0/24)
SSID2 should not access SSID1. The SSID2 will only have access to the Internet thanks to a captive portal.
My question: do you have to create one or two VLANs?
How should I configure my USG?
Thank you in advance for your invaluable help.
Damien
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,482
    100 Answers 1000 Comments Friend Collector Ninth Anniversary
    image  Zyxel Employee
    edited September 2018
    Hi @DamienSIMON
    You can setup configuration by these steps:
    (1) Create a VLAN for SSID2. Configuration > Network > Interface > VLAN > Click Add button.
    (2) Create a Zone for VLAN10. Configuration > Object > Zone > Click Add.
    (3) Create SSID1. Configuration > Object > AP Profile > SSID > Click Add button.
    (4) Create SSID2. Configuration > Object > AP Profile > SSID > Click Add button.
    (5)   Add SSID into AP Group. Configuration > Wireless > AP Management > AP Group > Click Add Button.
    (6) Apply AP group object to your AP. Configuration > Wireless > AP Management > Mngt. AP List > Edit “YourAP”
    (7) Drop traffic from SSID2(VLAN10) to SSID1(LAN1) and allow traffic to internet. Configuration  > Security Policy > Policy control > click Add rule.
