Wan failover
Hi all ,
I have configured wan failover to use secondary connection when primary fails, but i have noticed that i have trunk load balancing configured ? is there a way to configure just to have wan failover without load balancing on trunk.
Thanks in advance
Adi
Not done a failover but heres what might work
make two rounting rules
The highest one with like
Incoming = Interface
member = LAN1
Next hop
type = Interface
interface = wan1
Address Translation
Source Network Address Translation = outgoing-interface
Advance
check = Disable policy route automatically while Interface link down
check = Enable Connectivity Check
address ISP WAN gateway IP or 8.8.8.8
Lowest rule secondary connection
member = LAN1
Next hop
type = Interface
interface = wan2
Address Translation
When checking ping fails the highest rule will disable to allow the lowest rule.
Hi @adi_dragnic,
You can create an "User Configured Trunk" and add the secondary wan as "Passive" mode.
Then select this WAN Trunk to replace the system default one.
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
