WAX610d unreachable, LED status not described in manual
MortenKnak
Within my local site, I have a number of WAX610d. At first all were fully functional, but after 48 hours, I lost connection with one. After having tried rebooting and resetting, I still get the same LED-cycle: 10 seconds Green, 20 seconds Amber, 90 seconds Green/Amber 1s/1s blinking.
What does the LED cycle mean, and is there a trick to overcome this state, or is it a warranty matter?
Looking forward to hearing any thoughts - regarding this...
/Morten
/Morten
Hi @MortenKnakPlease connect the AP to the network and use ZON to scan if the AP is alive or not.https://www.zyxel.com/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
If the DHCP is fine but AP still cannot be reached, we suggest to send the AP back to RMA.
You can contact with your reseller or let me know your country. I will provide the local support to you.
Joslyn1
Hi @MortenKnak
Need your help to provide some information.
1. Can you help to confirm if the AP got enough power to work?
2. Did the AP get IP address successfully?
Please change the power source and observe if the AP can bootup succesfully or not.
Just let me know the result.
Thanks.
Joslyn0 -
Hi @Zyxel_Joslyn , thanks for replying.
Regarding the power, it consumes 2.9 watts, it is connected to a GS1920-24HP, port is enabled.
I have a suspicion that the network interface is the issue, since the switch only delivers the power?
Thus - off course - it does not receive an IP. I have had it connected locally to another poe-switch, but the result is similar: powered up, but no connection/IP, and the mentioned LED cycle.
/Morten0 -
Joslyn1 -
Hi @Zyxel_Joslyn, thanks again.
I will go with the RMA-option with my reseller, as the NIC does not respond.
/Morten0
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
