What is the expected wifi speed for a USG60W?
usamarathoner
usamarathoner Posts: 2
Third Anniversary
image  Freshman Member
I am getting around 2.4G 27Mbps
  • usamarathoner
    Third Anniversary
    Ethernet Wired WAN into the USG60W is getting 300+Mbps
  • CHS
    CHS Posts: 181
    image  Master Member
    In default radio profile, channel width is 20 MHz.
    You can change it as 20/40 MHz may get higher speed.
  • mMontana
    mMontana Posts: 1,509
    image  Guru Member
    Which network adapter are you using? In which zone is your WLAN?
    PeterUK Posts: 4,754
    image  Guru Member
    edited September 2021
    Then built in AP on the USG60W only support 20MHz on 2.4G
    I get over 50Mb on 2.4G my USG60W depending on line of sight to it
  • CHS
    CHS Posts: 181
    image  Master Member
    Thanks for your answer. It looks performance may affect by wireless environment.
    Use 5G band may get better speed.
