Where can I buy power adapter for WAX610D
Would anyone kindly advise/recommend the type of power adapter for WAX610D ? Appreciate if you could share some experience on this.
Have thought of buying a managed PoE switch that support 2.5GbE, but probably a managed 2.5GbE switch + Power adapter is a better choice?
Dear @NKOB,
Welcome to Zyxel Community!
Regarding the type of power adapter for WAX610D, you may consider the one that with the following specifications.
Input: 100-240V ~ 50/60Hz
Output: DC 12V – 1A
If you would like to buy from us, you may find our local distributors from the following link:
https://www.zyxel.com/where_to_buy/where-to-buy.shtml
For your second question about managed 2.5GbE switch, due to we don’t know how many ports that you would like to use, here we provide some models for your reference.
XGS1210-12, 12-Port Web-Managed Multi-Gigabit Switch with 2-Port 2.5G and 2-Port 10G SFP+
https://www.zyxel.com/products_services/12-Port-Web-Managed-Multi-Gigabit-Switch-with-2-Port-2-5G-and-2-Port-10G-SFP--XGS1210-12/specifications
XGS1250-12, 12-Port Web-Managed Multi-Gigabit Switch includes 3-Port 10G and 1-Port 10G SFP+
https://www.zyxel.com/products_services/12-Port-Web-Managed-Multi-Gigabit-Switch-includes-3-Port-10G-and-1-Port-10G-SFP--XGS1250-12/specifications
XS1930 Series
https://www.zyxel.com/products_services/10-12-port-Multi-Gigabit-Smart-Managed-Switch-XS1930-Series/specifications
Regards,
Nathan
Dear @NKOB,
Output: DC 12V – 1A
XS1930 Series
Regards,
Nathan
APs using POE are easier to place and manage. No outlet needs to be nearby and you can turn off the power through your POE switch if needed (shutdown is always better if possible). Long runs easily possible with better cable. Almost no voltage drops with CAT 8 22 AWG, Cat 6A also very good. You could also use a POE power injector with a regular switch which would make the AP easier to place.
If you are using stand-alone mode with the AP, you will need some patience. Zyxel prefers Nebula then AP management first (on USG Flex, etc).0
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
