Need rack mount kit for my XGS3700-48HP
adminpants
adminpants image  Freshman Member
edited August 2022 in Switch
Hi, I have a long APC rack and I'm looking for a rack mount kit for the model in subject
  • TomorrowOcean
    You should find it in the original brown box of your Switch~~
  • adminpants
    Both the rail kit and the box got lost some time ago. The rack depth is 55cm. Is there a model number and a supplier you would recommend for Switzerland or Germany?
  • Zyxel_Jason
    Zyxel_Jason image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @adminpants,
    Here is the online shop that sells the spare parts of Zyxel products.
    Zyxel - LetMeRepair direct (letmerepair-direct.de)
    However, unfortunately, the spare parts of XGS3700-48HP is not available now.
    From your description above, you would like to have the rail kit.
    Therefore, I can provide you the spec of the it:
    For the rear bracket:
    For the sliding rail:
    Hope it helps.
    Jason
