Router(config-wlan-radio test_24G)# output-power 50% % Command removed due to the platform upgrade.
Dzmitry
Dzmitry Posts: 1 image  Freshman Member
edited May 2024 in Wireless
How to solve the problem?
  • Zyxel_Bella
    Zyxel_Bella Posts: 576 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    edited December 2021 Answer ✓
    Hi @Dzmitry
    Thank you for reporting the observation.
    The command has changed the category, the current settings is at wlan-slot.
    If you want to edit radio 2.4GHz the command will be slot1 and 5GHz is slot2.
    Here is the example for changing the power of radio 5GHz:
    Router# configure terminal
    Router(config)# wlan slot2
    Router(config-wlan-slot)# output-power 30dBm
    Don’t hesitate to get back to me if you need any more information.
    Thank you
    Regards,
    Bella
  • Zyxel_Bella
    Hi @Dzmitry
    Thank you
    Regards,
    Bella
