Why Are There 2 Triangle Light Indicators For Every Port
businessuer
businessuer Posts: 134
image  Ally Member
edited August 2022 in Switch
For zyxel switches, why Are There 2 Triangle Light Indicators For Every Port?
I understand that those pointing to the top refers to the interface on top.
I understand that those pointing to the bottom refers to the interface on bottom.
But why 2 triangles for each interface?
  • Zyxel_Chris
    Zyxel_Chris Posts: 739
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    image  Zyxel Employee
    @businessuer
    I'm not quite sure what you mean, which model are you use?
  • businessuer
    image  Ally Member
    @businessuer
    In the circled portion, there are 2 triangles up and 2 triangles down.
    I notice that when the interface is up, only 1 triangle will light up.
    What is the other triangle for?
  • Zyxel_Chris
    edited January 2022 Answer ✓
    @businessuer
    The green LED means link on 1G and the left one of amber means on 100M, you can refer to our user guide page 43.
    XGS4600-32_V4.70_Ed1.pdf (zyxel.com)
    Also on front panel sticker has also poin it out.  :)
