USG 200 PROBLEMS
rudaisssssssssssssss
in Security
I have buy an USG 200 in Ebay UK with "TESTED OK" but when start, SYS blink.
With debug mode and put firmware or put database , i have Firmware Received but error 255 (my windows firewall is off). I turn in rond. Help me. When i start :
FLASH: AMD 16M
FLASH: AMD 16M
BootModule Version: V1.08 | 12/04/2007 15:36:17
DRAM: Size = 256 Mbytes
DRAM POST: Testing: 262144K
DRAM Test SUCCESS !
Kernel Version: V2.4.27 | 2015-01-08 21:37:16
ZLD Version: V3.30(AQU.7) | 2015-01-13 16:31:04
Press any key to enter debug mode within 3 seconds.
Start to check file system...
/dev/hda2: 18/18216 files (0.0% non-contiguous), 33806/72704 blocks
/dev/hda3: 42/43648 files (0.0% non-contiguous), 11206/174080 blocks
Done
mount: wrong fs type, bad option, bad superblock on /dev/loop0,
missing codepage or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
Kernel panic - not syncing: Attempted to kill init!
Rebooting in 180 seconds..
AFTER PUSH THE DATABASE :
[Update Filesystem]
Updating Database
mv: db/etc/zyxel/ftp/conf: file not found
mv: db/etc/zyxel/ftp/script: file not found
Nothing in directories...
Why?
Thank you
Why?
Thank you
ok now after put RI file with xmodem transfer.0
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
