SSLVPN not able to connect to LAN1
LAN1 client (10.10.100.9)
SSL VPN client (10.10.200.11)
SSL VPN client can not ping 10.10.200.1
SSL VPN client (SecuExtender) connect successfully (including 2FA with email)
try all different suggestions, need help please
I'm missing a security rule or routing problem ?
Where should I check the log ?
Hi @tkgn,
Welcome to Zyxel community.
Please go to "CONFIGURATION > VPN > SSL VPN > Global Setting page, and modify Network extension Local IP to 192.168.200.1. it would have routing issue if Network extension Local IP is same subnet as VPN pool.
Their will be no DNS at 10.10.200.1 you need to use 10.10.100.1
Also the LAN1 client (10.10.100.9) willl not use 10.10.200.11 by SSL VPN to get to 10.10.100.10 say because windows will use 10.10.100.9 to get to 10.10.100.10.
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
