USG60W Wifi problem
Zeezee
Zeezee Posts: 4
image  Freshman Member
edited April 2021 in Security
Hi All,
Our USG60W started logging Wireless LAN Alert stating: "Wifi watchdog cannot detect 2.4G/5G card!".
Currently we are not using the Wifi of the USG60W. Wifi had to be "turned off" after the latest firmware update, because 2.4GHz band stopped working. We are able to use 5GHz Wifi only. Wifi alwasy goes to 5GHz regardless the radio settings. Ideally we would use Wifi (if both bands were available).
Is this a hardware issue? Any help/suggestion would be appreciated.
  • ChrisGer
    ChrisGer Posts: 206
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
    image  Ally Member
    Hi @Zeezee
    if you are disableing the internal WLAN, what model of ZYXEL managed-AP are you using?
    i've a USG60W with the latest WK Firmware and no issues and I have the internal and the managed APs (3560N and 5560N -> external) in a AP group successful in production.
    Have you raised a ticket by ZYXEL in your country to test and isolate the error ?
    Regards
    Christian
  • CHS
    CHS Posts: 181
    image  Master Member
    Hi @Zeezee
    I have met it before. But it seems not happening again after I reboot device.
    Does your symptom happening every time?
  • Zeezee
    Zeezee Posts: 4
    Hi @Zeezee
    Regards
    Christian
    Hi Christian,
    We use no AP at the moment. We used the internal (only). I try to resolve this issue before raising a ticket - but I will.
  • Zeezee
    Zeezee Posts: 4
    CHS said:
    Hi @Zeezee
    Hi CHS,
    Reboot does not affect the symptom. I also tried to modify the country code in configuration for testing purposes (to US), but made no difference (tried other i.e. CH, etc.). Only 5G Wifi worked, even setting manually a 2.4Ghz radio (It went up to 5GHz ch 36 and no Wifi on 2.4GHz). That's why turned off the Wifi. But log always appears - regardless the Wifi is on or off.
  • Zeezee
    Zeezee Posts: 4
    As you mentioned that the symptom was gone after re-uploading 4.31 firmware, something might go wrong in previous firmware uploading process. Glad to hear that this issue was solved now.
    Now we upgraded to 4.32(AAKZ.0) - Wifi is stable and operational. Thanks for your help.
