LED RED - RESTART USG - 1100
D2IT
D2IT Posts: 20
image  Freshman Member
Good afternoon everyone, how are you?
We have USG1100 on a client, the firewall hangs and restarts, the SYS light is lit red, can you help me solve this problem?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,408
    100 Answers 500 Comments Friend Collector Sixth Anniversary
    image  Zyxel Employee
    May I know what is your current device firmware version?
    What is the hang symptom? I mean device Web-GUI cannot login? CPU high? no CLI response?
    How often this hang symptom occurs? Did it happen during office hours usually?
    How did you recover from this symptom? By rebooting the device?
    Do you enable UTM features(APP Patrol, Content filter, Anti-Malware, IPS,  etc.)?
    Do you enable Web-auth feature?
    Could you prepare a dedicated PC to keep collecting kernel-level-8 console log until the next time this symptom occurs again for us(Please type the command "debug kernel console-level 8" to enable kernel-debug-level 8.)?
    Thanks.
  • mMontana
    mMontana Posts: 1,514
    image  Guru Member
    What the manual says?
  • Zyxel_Jeff
    Thanks.
  • D2IT
    D2IT Posts: 20
    USG1100.   V4.72(AAPK.0)
    Firewall Access is unavailable. The CPU is stable!
    CLI access, unavailable.
    Every day, there is no set schedule!
    We restarted the firewall!
    All resources are activated, as it is a school, where there is a need to block and leave it very restricted!
  • Zyxel_Jeff
    Hello @D2IT
    If you need any assistance, please let us know.  Or you can provide the kernel-level-8 console log to us via private message. Thanks :).
