from LAN to LAN over bridge
I have USG Flex700 and I am manging two different ISP networks withthe ZyWALL - one is main ISP and the other is of legally-established entity.
I was able to set it up with the great help of this community - via bridge as described within
The bridge is defined as follows:
Policy route:
Of course some demands happened later on to access some resources over that bridge.
One of them was to access internal web page which belongs to that legally based network.
So I have set the Policy Route:
and Policy Control:
and it behaves really nice - people form one subnet 192.168.0.x can access web interface 192.168.94.200 as HTTP/HTTPS without any problem.
Then another demand came - access data on Synology share which resides within network 192.168.0.x FROM network 192.168.94.x.
So I have followed similar steps:
I have defined the corresponding subnet as interface subnet over the mentioned bridge:
then Policy Route:
and then Policy Control:
But to access Synology in this direction, it does not work at all.
Please share your proposals, experiences, ideas.
Thanks a lot
A dawning layout of the network might help.
But from what I see you want subnet 192.168.94.0/24 to connect to this 192.168.0.102? so are devices on 192.168.94.0/24 have gateway to the bridge IP?
@NoE
Is the scenario similar to this example? You may follow the steps in the guide "bridge_scenaro.pdf".
https://community.zyxel.com/en/discussion/comment/5137#Comment_51370 -
well, the GW of 192.168.94.0/20 is defined within the bridge itself:
dawn out a network layout
- 241 Nebula Ideas
- 6.8K Security
- 761 USG FLEX H Series
- 383 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
