Still problems with Client VPN connections after Update Firmware 4.73(AAPK.2)
Hi @FMGregor
To further investigate this issue, would it be possible for you to provide me with a private message containing the HTTPS access session? This will allow me to directly look into the matter.
Having a similar issue, where our FLEX200 fails to load up the config after FW updates, then defaults to stock settings. After forcing the load of our backup config, it all works, BUT that one VPN gateway forgot which certificate to use.
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
