Connecting 3 Managed Switches together
iammike
iammike Posts: 2
image  Freshman Member
edited June 2023 in Switch
new member here, hi.
I have bought for my LAN a GS1900 and 2x GS1200
Now because my router has only 2 ports what is the best way to connect the switches to each other to allow traffic (VLAN etc) to not create a bottle neck.
Connecting a cable from #1 to #2 and from #1 to #3?
#1 is the main switch (the GS1900)
TiA
    PeterUK Posts: 4,826
    image  Guru Member
    Sure GS1900 to router then the two GS1200 to GS1900 per port.
    What you want to avoid is high traffic devices not on the same switch
  • iammike
    iammike Posts: 2
    thx Peter.
    That high traffic not on the same switch could happen because the Main NAS will be on the GS1900
