WAX650S with poe12-60w and still limited power
edvhoerstelde
Is it possible to do it wrong? The WAX650S runs on limited power?!?
I had to force the full power mode for the AP.
Power Setting
Force overwrite the power mode to full power.
Note:
Only enable this when you are using a passive PoE injector which is not IEEE 802.3at/bt compliant. Abnormal reboots will happen in case of insufficient power wattage.0
Power Setting
Note:
- 244 Nebula Ideas
- 6.9K Security
- 803 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 537 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
